Ansys Free Student Software
License Error
    • Shaimaa
      Hello
      I have a problem with a fluid license when I do FSI coupling between fluid and structural analysis. I used academic peak age software 2020. the error attached below.
      thanks in advance.
    • ANSYS_MMadore
      You need to have 2 licenses available to run FSI and would need to set your license preferences in the Client ANSLIC_ADMIN Utility to 'Use a separate license for each application.'nnThanks,nMattn
    • Shaimaa
      Thanks a lot ,nAfter I used a separate license it worked.nRegards.n
