Tagged: batch-script, licence-manager, python, scripting, thermal
May 16, 2022 at 9:10 am
EricHDM
SubscriberHello,
I am currently facing an issue if licence management in the following process:
- I run a python script from the onglet scripting/run script file in the project page of Workbench 21R2
- This python script writes a .bat file in the dp0/sys/MECH folders which is supposed to launch a 22R2 thermal analysHowever, when I launch the .bat file manually (double click on it), it works perfectlyihis .bat works perfectlly when launched manuallysHowever, wWhen the python 21R2 launches the script, I have the follwing error (see awing error (in : the version of the client license must be greater or equal to the client FEAT_ANSYS versionattached files)
owever, when I launch the .bat file manually (double click on it), it works perfectly have found a similar issue in the discussion 9578 client-software not picking up on license for version 19 version 18 still works though. owever, it seems that the answer was given personnalo you know how can I get ride of this error and be able to execute the .bat throughwthe python script ? ihanksfully,t ric Heulhardyigive
May 16, 2022 at 9:16 amEricHDM
SubscriberIt seems that the texte managment has difficulties with dotted list, so I repost my comment again.
1) I run a python script from the onglet scripting/run script file in the project page of Workbench 21R2
2) This python script writes a .bat file in the dp0/sys/MECH folders which is supposed to launch a 22R2 thermal analysis
3) When I launch the .bat file manually (double click on it), it works perfectly
4) However, when the python 21R2 launches the script, I have the following error (see attached file : the version of the client license must be greater or equal to the client FEAT_ANSYS )
This topic is discussed in the discussion: 9578 client-software not picking up on license for version 19 version 18 still works though.
However, it seems that the answer was given personnally and not posted in the chat.
Do you know how can I get ride of this error and be able to execute the .bat throughwthe python script ?
Thanksfully Eric Heulhard
May 25, 2022 at 12:35 pmGeorge Karnos
Ansys EmployeeWhat is contained in the .bat file?
Are you launching the python script to launch the 21 R2 analysis from within 21R2 or R1, when it fails?
There was no attached file.
Please post the contents or screenshots as we are not permitted to open files.
Trending discussions- Error with workbench SceneGraphChart
- License Error
- Workbench error
- Workbench not opening
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
3694
2564
1765
1234
590
