February 18, 2018 at 7:06 am
June 28, 2018 at 11:42 pm
tsiriaks
Ansys EmployeeHello,
The key issue here is the error message "System clock has been set back"
This issue occurs when FlexNet checks file date of some random files on the system and compare with the system clock. If it finds any file that has the date into the future, the license will not work because it would automatically assume that the system clock has been tampered or set back.
Try to locate the files that have the future date and either delete them (if applicable) or change the date. You can look for some free-ware or just try using Windows Explorer > Date Modified > Then select date/month/year into the future. Make sure you can see all hidden/system files.
Win
December 19, 2019 at 10:22 am
December 19, 2019 at 3:10 pm
Forum Moderator -
September 17, 2020 at 2:39 pm
Fum4sz4
SubscriberI tried the method of finding the files with a future date, but it has system files, and the amount of files I found is huge. Is there any software I can use to make these changes at once? I still have the issuen -
September 17, 2020 at 7:22 pm
tsiriaks
Ansys EmployeeIf the future date happens in your system files, I'd recommend to reformat. There is something really wrong in the systems and it could potentially be from virus.n
- License Error
- how to open DesignModeler
- FlexNet Licensing – Not running
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
- Numerical Problem Size limits with a model that should run
8762
4658
3151
1678
1456
