Ansys Free Student Software
License problem
    • Sefa guluzadeh
      Could you please help me?
      my student version gives me such an license error.how can i fix it?
      License CheckOut Failed:
      FLEXlm Error Message:
      Request name cfd_solve_level3 does not exist in the licensing pool.
      No valid FLEXlm servers specified
    • peteroznewman
      Is this what happened immediately after installing the software?
      What version of the Ansys Student Version is this?
      • Sefa guluzadeh
        I worked 4 or 5 examples on the software.
        after trying the new examples suddenly it gives such an error-(Maximum licensed number of demo users already reached.)
        Then i reinstall and try to install it again i had the problem(error) which i mentioned on the 1st post.
        and like;
        ****License CheckOut Failed:
        No valid FLEXlm servers specified.
        what could be the reason and how can I fix ?
    • Sefa guluzadeh
      No,
      the version i downloaded was Student Version 2022 R1.
      The Error that i got was;
      1)Maximum licensed number of demo users already reached.
      What should i do?
    • peteroznewman
      Have you tried to Restart your computer?  That is always a good first thing to try if the software was previously working.
      The next thing to try is to type in %appdata% into a Windows Explorer app. You will see an Ansys folder. Rename that to Ansys-old in the Roaming folder. Now go up a level and down into the Local folder. You will see an Ansys folder. Rename that also.  Now start Ansys and see if that helped.
Viewing 3 reply threads
