September 13, 2018 at 8:42 pm
atswu
SubscriberHello,
I installed Ensight 10.2.7a. During the installation there was no prompt to enter a license location or server name. I set the environment variable Slimd8_servers to the server location and port, but upon opening Ensight, the program is unable to find the license location. This is the error message I get:
If I understand correctly, Ensight is using Flexnet instead of Slimd8, so why is it still asking for a slim8.key? How can I get the license to work?
September 13, 2018 at 11:04 pm
tsiriaks
Ansys EmployeeHi atswu,
Do you know if the license server is using the legacy Ensight License Manager or the ANSYS License Manager ?
If the latter is the case, on your machine, unset that environment that you set, then set these two instead
ENSIGHT10_LM=ansys
ANSYSLMD_LICENSE_FILE=
Note: Replace
with the actual port number used by FlexNet on the license server running ANSYS LM. This port is default to 1055.
Replace
with the actual server information (either server hostname, fqdn, or IP address)
Thank you,
Win
September 17, 2018 at 8:41 pm
September 17, 2018 at 8:42 pm
atswu
SubscriberAlso I am unsure which license manager the license server is using.
September 18, 2018 at 12:48 am
tsiriaks
I can't see the attachment for some reason. Can you re-post it ?
Please check with the server admin of that machine to see what License Manager is running. It should use ANSYS License Manager so that those two environment variables that I mentioned would work.
However, this also depends on what license you/your server admin has. If it's the legacy Ensight license, you still need to host it with the legacy Ensight License Manager and if this is the case, you can't use this Ensight version (10.2.7a) with that licensing. You have to find legacy Ensight product/installation package and use that one.
Thank you,
Win
September 20, 2018 at 3:04 pm
September 21, 2018 at 12:17 am
tsiriaks
Please check with the server admin if the license server is up and running.
If so, this is a network issue. The client machine can't communicate with the server. Please consult with your IT that the client machine can communicate with the server via port 2325.
Thank you,
Win
- Workbench error
- Workbench not opening
- License Error
2524
2064
1279
1096
456
