Ansys Products
Ansys Products
License Problem in mechanical APDL product luncher
    • oldbrothermin
      I used Geo-material which is not supported in workbench (model-111 johnson-holmquist concrete)
      Thus, this is my way to use LS-dyna
      1. make geometry In Mechanical APDL
      2. modeling & solving in workbench (k file making)
      3. open k file in Pre-post
      4. Input material in Pre-post
      5. save new k file
      6. solve in Mechanical APDL product luncher <== problem step
      7. check the result in Pre-Post
      I did modeling in workbench and solve the file (license worked)
      However, When I solve modified K file in APDL Product launcher It show error as figure
      Do you know what is problem in here?
      I need help....
    • Karthik R
      Administrator
      Hello,nThank you for sharing this issue with us. We will be answering this question soon.nThank you for your patience.nKarthikn
    • tsiriaks
      You may have a Windows environment variable LSTC_LICENSE set to network. nTry changing (or creating a new one if doesn't exist) it tonLSTC_LICENSE=ANSYSn
