June 7, 2019 at 7:43 am
helmut.schneider
SubscriberHello,
we had to reconfigure the pc - joined to a new Active Directory.
The system does not find a valid license file and some error messages occur. I already deinstalled SpaceClaim, but now changes in behavior.
I also cannot write the license key within the software as told from a supplier.
How can I solve this problem?
Best regards
June 7, 2019 at 8:21 am
l.janicek
SubscriberHi, I'm solving the same problem with our customer.
Temporarily, I solved the issue with help CMD.exe, but this is just a temporary solution without using an account, only with activation ID.
1. On the machine on which you want to activate a subscription, open a command window in the following ANSYS installation folder: ANSYS IncShared FilesLicensingwinx64
2. Run the following command, replacingwith the desired activation ID from this text file: ansysls_client.exe -ActivateLicenseEntitlement
I hope it helps you.
Have a nice day, Lukas
June 26, 2019 at 10:44 am
Naresh Patre
Ansys EmployeeHello Helmut Schneider Lukas
The server issue was fixed last week and the activations can be released from the account page. Please let me know if you still see any issues.
June 26, 2019 at 11:22 am
helmut.schneider
SubscriberThe activation works again. Thanks!
3740
2570
1785
1236
594
