Ansys Products
Ansys Products
License server error
    • nihar21
      I've just installed Discovery Aim Student 2019 R2, but when I try to run the software after installation, I get the following error. Any help would be appreciated.
      Thank you.
    • tsiriaks
      Open the content of that student.lic file and see if the license has expired.
      If not, open CMD Prompt and enter the following commands
      "%awp_root194%..Shared FilesLicensingwinx64ansysli_util" -checkout AIM
      set
      then post screenshots of the outputs.
    • nihar21
      Hey tsiriaks, thank you for your reply. I had installed 2018 version and the license was expired so, I had to download 2020 license key and replace the older key with 2020 one. This solved my problem.
    • tsiriaks
      that's great to hear !  Thanks for the update.
      Yes, that's the workaround to keep using the old version of ANSYS.
      It's still encouraged, however, to use the latest version.
    • Saneel
      Hey nihar21 i am also facing the same problem could you please tell me from where you downloaded the new license key and what was the further procedure ?n
Viewing 4 reply threads
