December 29, 2020 at 4:01 pm
December 30, 2020 at 6:14 am
Subashni Ravichandran
Ansys EmployeeHello Ghassan. AbuSultanah Could you please specify if you have the subscription or Floating license? If you have the Subscription license, you can change the mode of licensing. Please go through this post for the same.-
January 15, 2021 at 8:18 pm
ghassan.abusultanah
SubscriberSubashni I believe it's Floating license, I change the mode as per you link but the issue not solved and I can't open the software.
January 18, 2021 at 10:03 am
I see from my database that you have the Subscription mode of License and I also see that the license has been activated on one device.
Could you please change the licensing mode to subscription and launch the Application? You will be prompted to give login details after which you should be able to use the application.
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Dwg export error
- problem to access on the spaceclaim help
- Unexpected graphics error
- Discovery Getting Crashed
- BUG to correct is important
- Error messages running solver
- Critical error
- Discovery Live freezes with multiple load cases while topology optimization
3670
2550
1749
1226
582
