August 30, 2018 at 8:24 pm
DmitriiKruglov
SubscriberHello,
After I completely deleted version 17 HFSS desk software and the license manager (I followed the guide on the ANSYS website) and installed the new version 19 of both, I got problems with the software trying to connect to the license server. Our license has expired couple of days ago, and we are running on 2 weeks extension now, I received and added the new license key into the License manager, but the error is still there. I hope somebody could help us with this problem.
Thanks,
Dmitrii
August 30, 2018 at 8:49 pm
tsiriaks
Ansys EmployeeHello Dmitrii,
HFSS requires certain network communications with the license server to pull the license. More specifically it must be able to communicate with FlexNet (default is TCP port 1055) and ANSYS vendor daemon 'ansyslmd' (default is a dynamic port).
Please try the followings instructions to make sure that client can communicate with ANSYS vendor daemon on the server:
There are two options:
1. (Windows only) Add firewall exception to the executable ansyslmd.exe in C:Program FilesANSYS IncShared FilesLicensingwinx64
or
2. Open the port that ansyslmd runs on ; however , you must first set that to be static as it runs on dynamic port by default.
To set the ansyslmd port to be static , please go to this (default location)
(Windows) C:Program FilesANSYS IncShared FilesLicensinglicense_files
(Linux) ../ansys_inc/shared_files/licensing/license_files
, and modify the VENDOR line in every .lic files
so that it looks like this
VENDOR ansyslmd PORT=1056
(of course, you can use other port aside from 1056 as well)
Please make sure that you restart the ANSYS License Manager after you edit this.
Please let us know how it goes.
Thank you,
Win
September 4, 2018 at 6:57 pm
DmitriiKruglov
SubscriberThank you, Win! Port was the problem, we figure it out.
September 4, 2018 at 9:23 pm
tsiriaks
Ansys EmployeeThat's great !
Thank you for the confirmation.
Win
- Workbench error
- Workbench not opening
- License Error
2534
2066
1285
1104
459
