January 30, 2023 at 4:15 am
wolfgang.geist
SubscriberHi,
technical support is reporting 2 license server problem of our customer installations. Starting of ANSYS SpaceClaim/and or Discovery is resulting in an error message not seen before. As the licenses are in use for productive jobs and services they suffer from this failure. Please check and find a solution. Thanks and regards
Wolfgang Geist
Our partner has sent a message already
January 30, 2023 at 4:59 am
Subashni Ravichandran
Forum ModeratorHello Ghost1246
Can you please work with them on activating through Discovery Subscription license - Command line options ?
In the meantime, I can check with the team regarding the server.
January 30, 2023 at 8:11 am
wolfgang.geist
SubscriberHi Subashni, attached you find video which will tell you what problem we are facing at the moment. Please find a solution asap.
Thanks and regards
Wolfgang Geist
February 1, 2023 at 12:28 am
We are currently facing this issue with a lot of customers and out Development team is working on fixing this issue as soon as possible.
The only work around currently is to activate the licenses using the Command prompt options as suggested previously.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7780
4508
2973
1449
1322
