July 30, 2018 at 7:36 pm
ashish35
SubscriberHello,
I have got hybrid product license pack for ANSYS 19.1. Everything runs smooth with the software, however, once in a while, I get a licensing error message saying "The shared license is not available to perform Geometry Attach operation" while trying to load up the imported geometry in ANSYS Mechanical. Once I get this error, I would not be able to open ANSYS Mechanical throughout the day. Would be really helpful if I get to run this feature throughout the license period without any obstruction.
Thank you,
Ashish
July 30, 2018 at 9:17 pm
tsiriaks
Ansys EmployeeHi Ashish,
That error message would appear when there is another operation going on that won't allow the license to be shared , such as meshing or solving, etc.
Please check if there is such operation running anywhere.
One remedy to this issue is to set to use a 'separate license' Note: This option should be used only if you have many tasks of a license. If you have only one task of each license, do not use this as this settings would consume more licenses, than the default setting to try to share the license.
Try this
Close all ANSYS applications.
Open CMD Prompt then use the following entire command including the quotation marks (but make sure to change your installation path accordingly)
"C:Program FilesANSYS Incv191commonfilestoolswinx64ansyslm_relutil" -userprefs
This should launch the 'License Preferences' GUI.
On the bottom left, select 'Use a separate license for each application' > OK
Thank you,
Win
August 11, 2018 at 8:52 pm
ashish35
SubscriberDear Win,
Thank you so much. This is resolved now.
Best,
Ashish
Simulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- Workbench not opening
- Workbench error
- License Error
- Licensing Error
- Error with lumerical license activation.
- ANSYS 19.1 installation on Linux
613
562
220
188
128
© 2022 Copyright ANSYS, Inc. All rights reserved.
