Ansys Products
Ansys Products
Licensing Error
    • aidanweeks95
      Hello all,       I've just downloaded Ansys 19.2 student version on my home computer for university work. But as I try to open Mechanical APDL/Product Launcher and most programs I come across "this is a fatal error, exiting." where Ansys can not connect to any license serves.   Please can anybody help with this?
    • tsiriaks
      Hi aidanweeks95,
      Could you attach the screenshot of the error message ?
      If it's something similar to the issue here
      https://studentcommunity.ansys.com/thread/licensing-issue-after-starting-spaceclaim/?order=all#comment-565b81f3-565b-494b-a041-a93f0159292d
      you can try the resolutions described there.
      Thank you,
      Win
    • aidanweeks95
      Hi
      I will attach it now thanks
    • tsiriaks
      Could be due to a similar cause to the issue here
      Please try the resolutions there and let us know how it goes.
      Thank you,
      Win
    • aidanweeks95
      When I search "%temp%.ansys" in windows I find 0 results. So that is unfortunately no good, anything else?
      Aidan
    • tsiriaks
      Check your username and computer name and make sure that they only have English letters.
      Thanks,
      Win
    • aidanweeks95
      I had already done that! Still getting a license error
      Aidan
    • tsiriaks
      Open CMD Prompt, then issue the following command
      set
      capture the screenshot of the output and post it here.
      Also, this "%temp%.ansys" is not the search from Windows File Explorer, it's the search box on Windows Taskbar (the one next to Windows Start Menu).
      Thanks,
      Win
    • aidanweeks95
      Hi,  here is screenshot. And I did search the last bit on the Windows Taskbar
      Aidan
    • tsiriaks
      Try manually browse to
      C:UsersaidanweeksAppDataLocalTemp.ansys
      then look for the file that says 'demo..log'
      Open this file up and scroll to the bottom of the file and post the screenshot of it
      Thanks,
      Win
Viewing 9 reply threads
