September 19, 2023 at 4:52 pm
September 20, 2023 at 11:22 am
Rajeshwari Jadhav
Ansys EmployeeHi Aneela,
Are you able to ping your server?
September 20, 2023 at 4:08 pm
Aneela Banda
SubscriberHi Rajeshwwari,
how to do that. should i have to install the licensing manager?
September 20, 2023 at 4:15 pm
Aneela Banda
Subscriberthe user has licensing and ansys working on his personal computer. We wanted to use the same licensing on the HPC and has the file based version of it. so where should i move the file to and how to get it configured in a way that the user should be able to use the licensing on both HPC and users system
September 20, 2023 at 4:24 pm
Rajeshwari Jadhav
Have you installed a student version or an Academic version?
September 20, 2023 at 4:27 pm
Aneela Banda
SubscriberI have installed academic version of Ansys fluent 2022R2
September 20, 2023 at 4:35 pm
Rajeshwari Jadhav
Ansys EmployeeYou just need to point your application to the server.Â
First check if are you able to ping or telnet your license server, in the command prompt try using cmd “ping servername” and “telnet servername 1055?
To ON telnet service go to start and search “Turn Windows feature on or off” check box “Telnet Client” and click ok.
Go to the start menu and open the command prompt, and run the below-mentioned commands:
1.           ping servername
type this command and send the screenshot of the output.
2.           telnet servername port_number
The default port number is 1055.
A blank screen will confirm that you are connected, if you get any other output, please provide a screenshot of the same.
September 20, 2023 at 4:43 pm
Aneela Banda
Subscriberthe application is installed on RHEL 8.5
September 20, 2023 at 4:49 pm
Rajeshwari Jadhav
Ansys EmployeeYeah I missed that part, then too can you open terminal and run following command:
1.            ping servername         //instead of servername mention your server's name
September 20, 2023 at 4:54 pm
September 21, 2023 at 3:23 pm
Aneela Banda
SubscriberHi Rageshwari,
We have Ansys 2022 R2 installed in HPC environment where we cannot ping to other servers. So, we wanted to manually configure the file based licensing on HPCÂ
September 29, 2023 at 4:14 pm
Rajeshwari Jadhav
Can you go to ANSYS Inc/Shared Files/licensing and edit ansyslmd.ini. In the ansyslmd.ini file you can mention the server name with port no. ex. SERVER=1055@localhost
October 2, 2023 at 5:48 pm
October 2, 2023 at 5:54 pm
- License Error
- Workbench not opening
- Workbench error
- how to open DesignModeler
- FlexNet Licensing – Not running
7742
4504
2971
1449
1322
