March 2, 2022 at 3:34 pm
Luke.dykstra
SubscriberHello,
I am having trouble figuring out the best way to scope and add rigid beams, representing lifting chains, to a skid lift. I need to have the lifting done at a 20 degree angle from the vertical plane (screen shot 1) as shown below.
For a second analysis I need to add a compound angle so that it lifts from 20 degrees from the vertical(screen shot 1)and also 20 degrees from the side plane (screen shot 2).
I fell that this should be pretty easy but not sure if it is better to do it in DM/Space Claim or within workbench. Is it possible to add coordinates and remote points at an angle at the lifting locations? Do i need to set a remote point in space above the CG that will produce the 20 degree angle that is needed? Then scope a rigid beam of spring with a high k factor from point A to point B?
I tried to think if face splits was best to use but that seems to be limiting and does not seem to be the most efficient way to do it. Any insight or help on this setup would be greatly appreciated.
Thank you much.
March 4, 2022 at 8:49 amAshish Khemka
Please see if the following link helps:
How can I analyze the lifting process with ANSYS? 4 lifting holes are provided. ÔÇö Ansys Learning Forum
Regards Ashish Khemka
2610
2088
1321
1108
459
