Process Integration and Design Optimization
Light Propagation inside brain
    • Ali Momennezhad
      Hi everyone
      I am new to ZEMAX. I have an optical fiber with a 60-degree tilted mirror tip. I want to simulate the light propagation inside the brain.
      Consider these parameters:
      mean path: 0.086
      g=0.96
      transmission:0.5
      Henyey-Greenstein-bulk.DLL
      I am not sure I am doing it correctly as I think the tip of the fiber should be located inside the brain which here is the rectangular volume and also I don't know how exactly determine the NA of the optical fiber which should be 0.22. In addition, How can I have an optical fiber with a tilted mirror tip?
      Any help is appreciated.
    • Ali Momennezhad
      In fact I am trying to produce a result like this:
    • Elham Sarbazi
      Hi Ali,
      Thanks for reaching out. I appreciate the descriptions you have provided.
      1) For adjusting the numerical aperture of the optical fiber, you can have a look at a nice discussion in the Zemax community.
      Setting NA of the fiber in non - sequential mode | Zemax Community
      2) Regarding modeling an optical fiber with a tilted tip: for the Cylinder 2 Volume objects, you can set the tilt of the rear face of the fiber using the parameter(s) Back Angle Along X or Y.
      I suggest you to post your Zemax related questions to the Optical channel next time. To have a swift feedback, you can either post in the Zemax community or open a ticket in the Zemax support system.
