July 7, 2022 at 9:05 am
Xime54
SubscriberHi,
In order to understand Human eye sensors, I am making a simple simulation with only one source, wich is a display source. When the calculation is made, and the xmp map is displayed, I can see on it a reflected light, depending of the 3d view orientation:
I guess this is only for display, and it has no physical signification, I am right?
Regards
July 25, 2022 at 10:46 am
Fabien Bastide
Ansys EmployeeHi Maxime,
When you are opening the result on the xmp map, what do you see? From the info here it seems only related to how it is displayed in the direct modeling 3d environment. Do you have a screenshot of the result only?
Kind regards,
Fabien
July 25, 2022 at 11:24 am
Xime54
SubscriberDear Fabien,
I confirm you there is no reflected light when I open the result in XMP map.
Maxime
- 软件打不开
- Ganhemt Project mistake can you help me
- how to export results from SPEOS to Mechanical
- Simple Optical simulation
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- How to calculate the cross-polarization efficiency and phase in FDTD
- Negative Reflection Problem
- Inverse design of polymer y-branch – modify the example provided
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
2630
2104
1327
1110
461
