July 9, 2019 at 6:20 pm
ygauri
SubscriberHello,
Can anyone guide me on how to use line contact if two plates are being welded to each other on all edges.
July 9, 2019 at 11:36 pm
SubscriberAre you doing edge-to-edge connections? Set the geometry filter to edges. Insert a Contact, pick edges for the Target and the Contact side. The default is Bonded contact. This will simulate edges being welded.
July 10, 2019 at 12:03 am
July 10, 2019 at 12:43 am
SubscriberYou can pick the two faces, and use a Pinball radius to make sure there is a Connection Element in the Contact definition. The target side of the contact would be the large plate.
July 10, 2019 at 12:45 am
ygauri
Subscriberok sir, will try that, thanks.
3930
2649
1861
1272
610
