linear buckling of a cracked plate?!
    • elhamasadi
      Can anyone please explain if there is a way that I can perform linear buckling analysis on a cracked plate?
      The material is linear structural steel, and I have fixed BCs. on the both ends.
      As I try, this message appears:
      The current analysis is not supported with cracks defined under the fracture folder.
    • peteroznewman
      Delete the fracture folder.
      Open the geometry in SpaceClaim.
      Create the crack shape and subtract it from the solid.
    • elhamasadi
      I followed your method and it was ok, thank you.
    • elhamasadi
      How can I calculate the SIF (stress intensity factor) based on your specified model?
      As far as I know, using ANSYS fracture mechanics tool one just needs to specify the results under the SOLUTION menu.
    • peteroznewman
      Yes, the SIF is one of the results available in a Fracture Tool in the Solution branch of Mechanical.
Viewing 4 reply threads
