November 10, 2018 at 12:43 am
Aloush993
SubscriberHi ,I am modeling a structure and I made reinforcement , and in order to make properties for concrete and steel , I use apdl codes , but giving me errors and I have to submit the project soon , could you please help me in getting results ? as I don't know now the problem in geometry or reinforcement or what ? and please if need little modification do it and show me my mistake in order to learn
Note : there are 3 cross-sections: beam , columns and bars .I made pressure and fixed support at the bottom . everything is specified . I just want to get properties using the codes ( mentioned below ) and put pressures , could you please do this at the mechanical and show me the results ( I feel there is something in shared topology) and ( Put random value for pressure , I will understand)
Thank you
the spaceclaim file is attached and also the codes are mentioned below in this video
November 10, 2018 at 11:48 am
Aloush993
Subscriber?????
November 12, 2018 at 7:20 pm
Aloush993
Subscriberwhy no one help here ???!!!
November 13, 2018 at 1:15 pm
SubscriberAloush,
I'm sorry you have waited so long, but this free site consists of volunteers who have limited time to spend here.
The members on this site who work for ANSYS are not allowed to open files attached to posts.
In order to get help from them, you need to put into your post, details of the error messages you see and many screen snapshots that show a lot of detail of your model.
I don't work for ANSYS and sometimes open files attached to posts, but I have been too busy to do that lately.
November 17, 2018 at 2:44 pm
Aloush993
SubscriberThanks for your reply , I am modeling a frame structure, and I want to add reinforcement , I am facing no corporation between reinforcement and the concrete , the model show the reinforcement bars are out of the column , what is the solution ?
November 18, 2018 at 9:07 pm
SubscriberDid you use Shared Topology in DM or SC in order to have the reinforcement be connected with the concrete?
In order to get help, you need to put into your post, details of the model and many screen snapshots that show exactly what you did and what went wrong.
November 19, 2018 at 12:51 pm
Aloush993
Subscriberthe best shared topology for concrete with reinforcement connection is merged or share ?
November 19, 2018 at 1:07 pm
SubscriberShare.
November 19, 2018 at 1:26 pm
Aloush993
Subscriberthanks brother , I notice if I use beam dimension for line body ( rectangular as for column or beam ) I can't use the apdl code (solid 65) , how can I change the beam dimension as a body inorder to use the code ?
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2148
1359
1150
462
