December 5, 2022 at 7:46 pm
Swati Bhargava
SubscriberHi,
I'm using Linear taper from Object Library. I can Edit this object to set its properties. One of the property is named "index" . Any idea what does this represent? I think this does not represent the material refractive index because there is another property names "Material" where I can select the material and that will in turn determine the refractive index.
Below is the snapshot where index property is shown at #8: By default it was set to 1.4 . I'm not sure how to decide its value, unelss I know what it represents.
Here is what Script tab shows: It does not talk about the index property!
December 5, 2022 at 11:55 pm
Swati Bhargava
SubscriberI figured out that this is the dielectric index value. It seems to me that this parameter gets populated automatically based on the dielectric layer in the structure.
December 9, 2022 at 1:06 am
Taylor Robertson
Ansys EmployeeHello Swati,
This value will likely only be used if you have chosen object defined dielectric material, then it will be the assigned index n of the object.
- 软件打不开
- Ganhemt Project mistake can you help me
- how to export results from SPEOS to Mechanical
- Simple Optical simulation
- How to calculate the cross-polarization efficiency and phase in FDTD
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- Negative Reflection Problem
- Inverse design of polymer y-branch – modify the example provided
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
2656
2120
1347
1118
461
