March 5, 2023 at 6:33 am
aminuddin setyo
Subscriberhello, i wanna do soem linear analysis on my model
how to setup linear analysis?
because it seems that when I use the default setup (program controlled), it performs a non-linear analysis my model has several bounded contacts and 1 frictional contact,
so should I disable the stiffness update to never, then disable the non-linear effect on the geometry tree?
on the other hand I have also disabled large deformations Thank You -
March 5, 2023 at 12:23 pm
SubscriberFrictional contact is nonlinear.
If you change the Frictional contact to No Separation, that is a linear contact and then you can solve as a linear model.
3638
2502
1729
1224
578
