December 2, 2019 at 8:05 am
December 3, 2019 at 4:47 pm
DrAmine
Ansys EmployeeCheck filed under contour plots -
December 3, 2019 at 5:37 pm
khalidb77
SubscriberHi Mr. Abenhadj
I not willing to use filled contours I want to use lines only.
Thank you
December 4, 2019 at 12:00 pm
Ansys EmployeeThe result is showing the field without filled contours: the result is that the bounds between each level are "winding". What do you expect to see?
December 6, 2019 at 11:31 am
December 6, 2019 at 5:54 pm
DrAmine
Ansys EmployeeDo not select any boundary and choose option filled. Use actual version. 15.0 is not supported. -
December 6, 2019 at 6:02 pm
khalidb77
SubscriberDo not select any boundary and choose option filled. Use actual version. 15.0 is not supported.
Excuse me Mr. Amine may you tell me what the thing that not supported in version 15?
regards,
Khalid
December 6, 2019 at 6:04 pm
DrAmine
Ansys EmployeeNo your software is not supported. -
December 6, 2019 at 6:10 pm
khalidb77
SubscriberNo your software is not supported.
But it works well with me and simulations run with it?
December 6, 2019 at 6:12 pm
DrAmine
Ansys EmployeeYes, that was just an info in case there is something buggy.
Now what about the contour plot? -
December 7, 2019 at 8:02 am
khalidb77
Yes I do not select any boundary and again I am not hoping to use fill option
Khalid
December 7, 2019 at 10:05 am
DrAmine
Ansys EmployeeDo you want to see contour? Please use filled option and post the picture.
5370
3363
2471
1310
1020
