Discovery Import
Discovery Import
Lineweight (layout sketch) does not work on Japanese language (not only 2019R3)
    • kawabata
      Under language: Japanese on SpaceClaim Options, lineweight of layout sketch is unable to change (regardless > Show > lineweight ). Under language: English, it works correctly.
      #How to reproduce:
      0. Change language to Japanese on SpaceClaim Options
      1. Create a line on sketch mode
      2. Select the line and change Layout to "True"
      3. Change the lineweight on Lineweight command
      For changing lineweight, switching language is very inconvenience. Would you fix it?
       Thanks,
         Ichiro
    • Subashni Ravichandran
      Hello Ichiro
      I'm looking into your issue.
      I'll get back to you on this.
      Hello Ichiro
      Sorry for the delay in response. I could not get back to you sooner as I was unwell.
      I have filed a Bug (52931) for this issue. Thank you for reporting it!
      • kawabata
        Hello Subashni ,
        Thank you for filing and letting me know.
          Ichiro
