January 25, 2023 at 4:02 pm
Tom Allison
SubscriberGuys,
I'm trying to do a pre-stressed eigenvalue buckling analysis in Ansys Cloud.
I'm coming across an error in the Ansys Cloud extension that says 'linked analysis is not supported.' See the screenshots.
Has anyone come across this error? Can I use Ansys Cloud to solve the linked analysis?
Thanks!
Ansys Cloud Error
My Workbench Setup
January 31, 2023 at 3:26 pm
Mike Rife
Ansys EmployeeHi Tom Allison
This is expected as the Mechanical Cloud wizard does not support solving the down-stream systems of linked analyses. You can still use the Cloud Direct to solve these by:
1 Using a VDI then solving 'locally'
2 On the down-stream analyses use the "Write Input File" option. Edit the ds.dat as needed (may be some commands using reference to local file(s)). Gather the needed up-stream files and the ds.dat to one folder. Then use the Cloud command line to start the job.
Mike
January 31, 2023 at 3:37 pm
Tom Allison
SubscriberHi Mike,
Thank you very much for confirming this. I've been using your method 1 above as a workaround, but it does use up more AEC as you have to rent the machine for all the pre-processing.
Are you able to expand slightly on your method 2 please? Some more detail on the commands that I'd need to use and the specific files that I'd need to collate would be really helpful.
Many thanks,
Tom
January 31, 2023 at 3:51 pm
Mike Rife
You can do the pre-processing locally at your computer. Then create a WB archive and transfer that to the VDI session.
For the second method, see section 7.4.3 of the Ansys Help here:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/ans_str/Hlp_G_STR7_5.html
In the ds.dat you might need to edit the 'resume' command depending on the version you are using. Since you are using the Ansys Cloud Direct you are a customer so I would suggest opening an technical support Service Request. That way you can walk through the procedure 'live' with a technical support engineer. And maybe talk other types of linked systems if necessary.
Mike
January 31, 2023 at 3:54 pm
Mike Rife
I should have added that if gravity, or another constant load, is included then linear buckling is often a repeated process in order to get the eigenvalue close to 1, and so easier by VDI. -
January 31, 2023 at 5:23 pm
Tom Allison
SubscriberMike,
Thank you very much for all of your help. I'll keep using the VDI for now, but will use the ds.dat method on a smaller analysis as a test in the near future.
Many thanks,
Tom
- Installing Ansys in other than C drive
- NO AGENT ACTIVE
- Learning Hub
- ANSYS Cloud
- ansys student R1 2022
- Tidak bisa login di cloud akses,karena password salah,padahal sudah benar
- Is it possible to configure BYOL with Academic Licenses?
- Downloading specific files
- Maxwell 3D submission error : “Unable to create archive”
- How do I sort files by time, size, or type in ascending or descending order?
2656
2120
1347
1118
461
