June 20, 2019 at 7:40 pm
maitchoukow
SubscriberHello:
We have several Linux boxes that after checking the license server file on port 1055, it goes and uses different TCP ports to keep working. I need to keep changing the firewall rules to allow the new ports. We do not have that issue on the windows client which are using the default TCP ports 1055 and 2325. Is there a way to hardcore the ports into the linux client to only use the default ports (1055 and 2325).
Thank you.
June 20, 2019 at 8:06 pm
George Karnos
Ansys EmployeeHello maitchoukow,
ANSYS Licensing on any system uses 3 ports.
By default:
LMGRD: 1055
ANSYS INTERCONNECT:2325
ANSYSLMD: Port designated by operating system of the license server machine.
This is the port that is dynamic.
To make it static, you can stop the license manager and edit the license file on the license server machine.
Add PORT=#### at the end of the vendor line.
EX:
SERVER LIC1 DISK_SERIAL_NUM=1e324fdc 1055
VENDOR ansyslmd PORT=1056
Restart the License Manager
This will make the License Manager use ports 1055, 1056, and 2325.
Hope this helps!
Best Regards,
Geo
June 21, 2019 at 8:32 pm
George Karnos
I just wanted to follow up on this...
Did the information help?
If so, can you mark this completed?
Thanks,
Geo
June 25, 2019 at 3:13 pm
maitchoukow
SubscriberHello Geo:
Sorry that i didn't get back to you. I had to wait until i had a maintenance window.
I made the changes that you recommended and so far I haven't seen any issues. Thank you for your time and help.
Thanks,
Alex
June 26, 2019 at 8:13 pm
George Karnos
Ansys EmployeeExcellent!
If all is good, can you please mark this as Complete?
Best,
Geo
June 26, 2019 at 8:50 pm
maitchoukow
SubscriberI think I did. Please let me know otherwise.
- License Error
- Workbench error
- Workbench not opening
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
3720
2570
1783
1236
594
