March 12, 2023 at 1:55 pm
David trop
SubscriberHello , I want to use the Charge module to find the electric field inside Lithoium niobae create by Gold contact and
there is no Lithium Niobate as a material ' and I'm not sure if the option of adding it is quite right because it miss alot of material information
Does there is an option to do that in lumerical?
TNX
March 16, 2023 at 8:13 pm
Guilin Sun
Ansys EmployeeIt is not known for me what exactlythe electric intensity inside the material you want. Do you want to check the static field ? if so, you will need to make this material to be semiconductor. Please refer to this tip with proper material parameters:
Tips for creating a new semiconductor material
if you want to find mode intensity inside the waveguide with such material at a given wavelength please use FDE.
If you want to know the electric field intensity in the material at any wavelength you can simulate it with a broadband source in FDTD.
If the above are not what you expect, please elaborate more about the device and its working principle.
March 20, 2023 at 8:47 pm
Guilin Sun
Ansys EmployeePlease vote this feature at https://ix.lumerical.com/ideas/LUM-I-77 for this material in CHARGE.
March 21, 2023 at 7:05 am
David trop
SubscriberTnx , but what I wants is to calculate the Electric field inside structure and the put it inside FDE solver to see how its changes the neff (because Lithium niobate is an active material)
March 21, 2023 at 3:52 pm
Guilin Sun
Ansys Employee"Lithium niobate is an active material", yes, as semiconductor CHARGE can simulate isotropic material but Lithium niobate is anisotropic. right? in order to simulate the anisoptropic semiconductor CHARGE needs a new feature.
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
3850
2609
1853
1246
600
