LS Dyna
LS Dyna
Load Blast Enhanced / ALE Coupling – Over pressure duration time
    • pattonev
      Hi all!
      Im running into issues trying to model experimental data. I am attempting to match a pressure curve experimentally obtained with the LBE card. However, no matter which combonation in charge size and distance from my object, I cannot obtain the correct over pressure duration time. It seems that dyna wants to keep the overpressure time around 1ms give or take about 0.5ms. Ive tried looking into Kingery-Bulmash and Kinney-Graham curves as well and I cannot get an accurate overpressure duration time for that explosive charge and stand off distance.
      My experimental data has an overpressure duration time of 10ms. I am coupling with ALE as this is more of a jet of air in a small localized area that is best described as a blast (Friedlander) type pressure profile. The ALE helps me truncate blast wave to the area of interest. I wanted the most computationally cheap method of producing a spherical like pressure distribution that has the characteristic Friedlander profile since this loading is being integrated into a material model.
      Ive tried playing around with the density of ALE "air" elements to prolong the pressure duration and got it out to about 3-4ms before it became unstable. Can this overpressure time be obtained with this load card? or is this something I would need to model with a FSI type of approach? Any suggestions are greatly appreciated!
    • tslavik
      Please answer these questions.
      1- Which system of units is used?
      2- What is the charge mass?
      3- What is the shortest distance from the charge center to the ambient element layer?
      4- At what distance from the ambient layer are you monitoring the pressure in the air?
      5- How are you monitoring pressure in the air? For example, *DATABASE_TRACER.
      6- Are the air elements cubes, i.e., perfect aspect ratio? What is the side length of an air element? Is a uniform mesh size used for the air?
      7- What was the density of the in the experiment?
      8- What was the ambient pressure of the air in the experiment?
      9- What explosive type was used in the experiment? Was the charge spherical? Was it suspended in air? What was the proximity of the nearest reflecting surface, e.g., the ground?
    • pattonev
      grams, cm, microseconds, Mbar
      50kgs (50,000 grams)
      140 meters I believe
      20mm
      Tracer
      Cubes, unsure of aspect ratio but somewhat close. Side length is 2mm.
      Air density is .001255g/cm3 but Ive been changing that to prolong the duration
      Ambient air pressure is near 0.
      No explosive in the experiment. Only air. essentially a jet of air. I am using LBE to capture the pressure behavior. I think this is why its not working out.
      Thanks for the help
    • tslavik
      I don't think *LOAD_BLAST is the right feature for your analysis. Depending on what you know about the complete thermodynamic state and flow conditions you could use: *BOUNDARY_AMBIENT_EOS with *BOUNDARY_PRESCRIBED_MOTION_SET or just *LOAD_SEGMENT_SET (but this could lead to oscillations at the boundary).
      ref: 2021071410000073
Viewing 3 reply threads
