March 18, 2022 at 5:04 pm
king79
SubscriberHi
I am using the *Define_curve module in Ls-prepost to simulate an arbitrary loading. I get the following error message when running the analysis:
Error 20445 (STR+445)
repeated points in load curve 12 point number 2
Error 20444 (STR+444)
load curve 12 has vertical slope
Check that this curve is correct
Is there something I am missing or doing wrong?
March 20, 2022 at 8:48 pmking79
SubscriberI able to solve the problem. Apparently, Ls-Prepost inserts an additional row of zeros whenever you import data to define plots.
March 21, 2022 at 3:14 pmAniket
Ansys EmployeeThanks for posting your resolution!
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2590
2080
1315
1108
459
