Load Factors for Buckling Analysis
    • Muhammad Zeeshan
      Hi there!
      Can anyone guide me with the following query & attached picture.
      I've developed 3 different types of I beams.
      1. Simple Beam of 200 x 80 x 5 x 2 with simply supported boundary conditions & a point load applied.
      2. Same beam with web having circular holes (100mm dia) @ 100mm c/c & both ends @50mm from first & last hole.
      3. Same beam with web having circular holes (100mm dia) @ 200mm c/c & both ends again @50mm from first & last hole.
      Now, when i'm solving it for buckling. The beam with no holes is having the least load factor while no.2 beam is having the largest load factors which i assume should be the opposite of it. Can anybody guide what's going wrong? I've kept everything constant (Boundary Conditions, Length of beam, Applied Load). Thanks.
    • peteroznewman
      What was the default element size in each case?  Maybe the beams with holes ended up with smaller elements.
    • Muhammad Zeeshan
      Hi peter!
      The element size was set to 50mm for all 3 conditions.
    • peteroznewman
      Remesh with 10mm element size to see if the results shift from the 50mm element size values.
    • Muhammad Zeeshan
      Alright, Peter. I'll do.
      Can I request you to check my other query as well please?
Viewing 4 reply threads
