February 2, 2023 at 1:50 am
Kareem Abdulla
SubscriberI am doing a parametric study but before doing that I have to verify the model with a lab results. In the lab they used incremental load until the specimen couldn't take any force then they noted the load subjectuded to the model and its deformation. Can I do that in Ansys or I have to key in a force, I mean can I use incremntal load and see at what force the model will stop resisting the load, or I'll just have to key in the final load from the lab experiment and get the deformation.
Thank you -
February 2, 2023 at 9:34 am
Erik Kostson
Ansys EmployeeHi
It is probably possible to do that to certain extent (depends on the final failure type to capture).
So we can ramp up the load gradually untill something fails say perhaps.
Search this forum and the internet you will find some examples:
https://forum.ansys.com/forums/topic/increasing-load-displacement-curve-in-joint-structure/
All the best
Erik
February 3, 2023 at 12:00 am
Kareem Abdulla
SubscriberThank you Erik so mcuh. The discussion you shared did help.
3281
2459
