November 5, 2018 at 1:28 pm
November 5, 2018 at 3:18 pm
DrAmine
Ansys EmployeeWhich compiler are using? Is it a 64 bit one?
November 6, 2018 at 2:32 am
Karthik R
AdministratorHello,
Just to add to Amine's point - please double check if you have installed the correct compiler version. Please visit the following link and make sure you have the right compiler according to the version of Fluent you are using.
https://forum.ansys.com/forums/topic/ansys-19-0-visual-studio-intel-parallel-studio-xe-version-required-for-upfs/
I hope this helps.
Best Regards,
Karthik
November 6, 2018 at 7:43 am
November 6, 2018 at 8:31 am
DrAmine
Ansys Employeeopen the x-86_x64 Cross Tools Command Prompt. Make sure it is x-64 and type cl to check if the installation was correct.
November 6, 2018 at 8:45 am
November 6, 2018 at 9:51 am
Ansys EmployeePlease also confirm that you've not used any command or "odd" characters in the full path. The German B looking symbol for double s being one of the odd characters!
November 6, 2018 at 9:56 am
Max4
SubscriberWhat do you mean by " command" ? In the full path, there isn´t any "odd" characters.
Maxime
November 6, 2018 at 10:59 am
Ansys EmployeeCommand characters would be ! " £ $ = + etc. Fluent is/was designed for UNIX so some of the characters we use in Windows will have a different meaning and so shouldn't be used. It's not that long ago that spaces in the directory structure caused problems.
November 6, 2018 at 11:11 am
Max4
SubscriberI haven´t such character in the full path. Do you think that a space in the directory structure could be the problem ? Directory structure of Ansys or VS ?
Maxime
November 6, 2018 at 11:53 am
DrAmine
Ansys EmployeeI have downloaded the same package and it is working fine. Just start Fluent from the cross command prompt and try to compile the UDF there. If it is not working I will suggest that you contact your IT.
2600
2088
1319
1108
459
