January 3, 2023 at 4:36 am
January 3, 2023 at 7:14 am
SRP
SubscriberHi
I suggest you to check the previous forum discussion on the synergy angle: How to calculate the Field Synergy Angle (FSA) ? (ansys.com)
If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
Thank you
January 3, 2023 at 8:06 am
Mary C
SubscriberHi SRP, thank you for the tips.
As I check the previous forum discussion on the synergy angle, the reply by Rob is "If you're using Fluent you can use a Custom Field Function, you may also need a UDF to move some of the gradient data into User Defined Memory. More details on the latter in the documentation.".
Which lead to my next confusion, where may I find the documentation for more details?
Thank you.
January 3, 2023 at 9:05 am
SRP
SubscriberHi,
Please refer the user's guide: 37.5. Custom Field Functions (ansys.com)
Also refer the Fluent customization manual: 6.1.8. User-Defined Memory Storage (ansys.com)
Hope you find this userful.
Thank you
2688
2130
1349
1136
461
