November 12, 2018 at 6:04 pm
Aya.hassan
SubscriberHello all,
I have solved a structure model in static structure module. I want to calculate local maximum stress which is the maximum for a defined region of interest in the model. In the next picture, the maximum principal results after I made a cut section. How can I calculate the maximum value of stress or show the results in the area marked with red.
November 15, 2018 at 1:33 pm
Aniket
Ansys EmployeeHi Aya.hassan,
I can see only one image here, instead of two like you said.
Do you have a mathematical definition of the area? Such as elements which have centroid x coordinate less than 10 mm? If yes, you can create a named selection based on the worksheet for the required elements and then scope the result to the named selection instead of the geometry.
If you don't have a mathematical definition of the area, you can still select the elements by using box select or Lasso select tools and scope the results to the selected elements.
2134
1349
1136
461
