Platform
Platform
Local Sensitivity and Sensitivities: what difference?
    • Dragana Jandric
      In DX we have 2 types of sensitivities:
      Local Sensitivity
      It is available in the Response Surface component. It represents the variation of an output parameter when a single input parameter varies, with all the other inputs to their current value (current Response Point).
      The variation of the output is simply calculated (if Axes Range = Use Min Max of the Output Parameter): (sign) 100 * one-parameter-varying range / all-parameters-varying range
      The sign is determined whether the Min happens before or after the Max.
      For example, let's look at this curve:
    • Keyur Kanade
      Thanks!n
