January 31, 2023 at 6:34 pm
Mohammadreza Hojati
SubscriberHi everyone. I have simulated a BLDC named A2212 with RMxprt in Ansys Maxwell. Its nominal power is 280W. Its coils consist of a stranded winding with 24 thin wires with 5 turns. The software has calculated its locked rotor current as 850 Amps. Is this logical or something wrong is with it? Anybody could help me with that? Thanks
February 8, 2023 at 5:23 am
Navya C
Ansys EmployeeHi Mohammadreza,
Which version of AEDT are you using?
Are you calculating this data in RMxprt or in Maxwell?
Can you share the design sheet/results screenshots of your RMxprt and Maxwell?
Navya
- Maxwell, HFSS or Q3D?
- Error
5454
3419
2473
1310
1022
