August 31, 2023 at 6:43 pm
September 1, 2023 at 4:10 am
Keyur Kanade
Ansys EmployeeFirst create simple 2 curves in DM and try to use Skin tool and check how it works. That will give you idea about it. If you have imported curves and from image it looks like the cuve is in the loop. Split that curve into 2 or 3 curves and then use Skin tool. You can also try SpaceClaim.
Please go through help manual for more details
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
September 1, 2023 at 6:02 am
Aras karimi
SubscriberI tried two symmetrical airfoils and managed to Loft them together. But I did not succeed for this asymmetric airfoil model. what should I do ?
September 1, 2023 at 6:19 am
Keyur Kanade
Ansys Employeesplit the curve into multiple curves and create multiple skin objects.
Keyur
September 1, 2023 at 11:42 am
Aras karimi
SubscriberI have another problem and that is that the curve of the airfoil seems broken in some areas and not smooth. I got the coordinates of the airfoil points from the Airfoiltools site, which has very few points. Is there a solution to this problem?
September 1, 2023 at 12:14 pm
Keyur Kanade
Ansys EmployeeYou can add that point. Please check the format for points import in DM. You will find it on this forum or in the help manual.
Keyur
September 1, 2023 at 12:37 pm
Aras karimi
SubscriberYes, I did exactly the same thing and converted the airfoil points into a readable text file in Design Modeler. After importing to Design Modeler and drawing it, the airfoil curve looks broken in some areas and is not smooth. I think the number of points is low.
Is there a way to fix this problem so that I have more points of this airfoil ?
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7626
4456
2955
1427
1322
