February 1, 2023 at 9:35 am
paul
SubscriberHello,
For a couple of weeks now (Begin of 2023) we are experiencing login issues at alot of customers. When starting up SpaceClaim, you can see the loginscreen for a split second and then dissapears again. SC will not start up.
We have to do the manual activation of the licenses.
Please note that this happens with all SC versions.
Are there any issues with the login currently known?
February 1, 2023 at 11:37 am
Devendra Badgujar
Forum ModeratorHello Paesc
Some other users have faced a similar issue, and the development is currently looking into it. I will keep you posted of any progress.
For now, please continue to suggest activation by command line. Thank you for your understanding!
Regards.
February 21, 2023 at 12:57 am
Devendra Badgujar
Please try this solution.
January 2023 Subscription Licensing Issue - Knowledge Base - Ansys Discovery Forum
Regards.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3155
1688
1478
