March 8, 2023 at 9:09 am
lm32
SubscriberHello everyone,
I am trying to solve a 2d problem, with a structured ALE mesh interacting with a Lagrangian structure. After a certain time, the material in the ALE mesh develops a very small timestep, so I would like to delete it using TDEATH. However, when the mesh is deleted, the simulation ends with the following message:
**** Error 40178 (SOL+178)
Material type 0 is unavailable for
2D plane and axisymmetric elementsDoes anyone have a suggestion what is happening? i only used material types with other numbers.
Thanks!
March 14, 2023 at 5:38 pm
ido
Ansys EmployeeIs this using ALE or SALE? Recently a bug has been fixed in SALE that may be related to this (TDEATH). Please try with the latest beta (today's version) first.
March 15, 2023 at 9:13 am
lm32
SubscriberHi Ido, Yes it is SALE. I am using ANSYS version 2023R1 (LS-DYNA Version R13). Which version should I try? -
March 15, 2023 at 3:22 pm
ido
Ansys EmployeePlease get today's version from our "beta" dir.
March 21, 2023 at 12:17 pm
lm32
SubscriberThanks for the advice, using LS-DYNA version R14 solved the bug, but unfortunately I now get the following message after TDEATH has passed:
*** Error 40502 (SOL+502)
node # 1303667 has out-of-range velocities
x-velocity= NaN
y-velocity= NaNI get this message for the nodes of the S-ALE mesh immediately after it is deleted. Is there a way to solve this for a 2D axisymmetric model?
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3930
2649
1863
1272
610
