November 27, 2020 at 4:20 pm
StevenChoong
SubscriberAnyone knows where the Neoprene Rubber material data in ANSYS is from? I would like to know its test standard.n -
December 10, 2020 at 4:53 pm
Gary Stofan
Ansys EmployeeThe material data in the Ansys samples are generally from engineering textbooks.nUsers are strongly encouraged to obtain and validate their own material properties from their material supplier.nA recommended reference site for material data is matweb.comn -
April 21, 2021 at 1:03 pm
David Mercier
Ansys EmployeeHi, if you use the Neoprene Rubber material data from Ansys Granta EduPack or Ansys Granta Selector, data are well referenced. As Gary said it is mainly textbooks, but data come also sometimes from suppliers or from websites.nn
June 26, 2023 at 3:12 pm
Joy Gupte
Subscriberhello, steven
Neprene rubber compound/sheet or product can be preapred with vriable specifcations. Tough the raw material remain same, alterations can be made by varying amount of filler, plasticizers, carbon, vulcanizing chemicals. You can find speficatons here- neoprene-rubber-sheet
June 27, 2023 at 9:39 am
Binoc ngoai
SubscriberNeoprene is a petrochemical substance, which means that it is made from petroleum in a factory. Polychloroprene is made with a process called free radical emulsion polymerization, which turns natural chloroprene into synthetic polychloroprene. territorial io
- The topic ‘Looking for Neoprene Rubber source’ is closed to new replies.
- Adding New Material
- Exothermal reaction kinetics
- Fatigue SN curve
- Curve Fitting – “Error Norm to Fit” expression
- material designer
- Ansys Granta Selector license problem
- Anyone experience in how to model a glass filled polyamide (Nylon)
- Multistack layer model
- Strain Life Parameter
- adding new material in Granta
8808
4658
3153
1680
1470
