March 8, 2021 at 4:04 pm
sonapreetha
SubscriberI want to design a reflect array antenna design. I would like to get the code to design the reflect array. Please help me by sharing the code.nThanks in advance!n -
March 9, 2021 at 3:16 pm
Praneeth
Ansys EmployeenPlease provide reference for your request to help us serve you better and also provide the version of tool you are using.nBest Regards, n -
March 10, 2021 at 12:57 am
sonapreetha
SubscriberDear @pmunaga ,n Thank you for your response. From the following link I found about the reflect array design script from Ansys . nI am using Ansys Electronics Desktop 2019 R1 version. nLooking forward to hear from you!nnRegards,n -
March 10, 2021 at 1:59 pm
Praneeth
Ansys EmployeenI am afraid to say that we cannot share these codes over the public forum. Kindly contact your Ansys contact representative regarding the code.nThank you for reaching to us.nAll the very best.nBest Regards, n -
March 10, 2021 at 4:29 pm
Zeba Naqvi
Ansys EmployeeIf you cannot get access for any reason, you could write your own code if you like. Utilize the 'record script to file' to see the commands related to the relevant actions in HFSS, and the scripting help. Then rest is regular logic of reflectarray design and knowledge of python which is freely available on internet. Read a few books on reflectarray antennas, google python commands, see Ansys commands through script record and you should be able to design reflect arrays independently! n
- Maxwell, HFSS or Q3D?
- Error
2706
2146
1357
1144
462
