Loosely Coupled CHT and Shell Conduction Compatibility
    • Ant
      Hello!
      I'm trying to perform a transient CHT calculation in Fluent. The model has Shell Conduction. When I click "Run calculation" I get an error:
      "Error: get-thread: invalid thread id (integer) or name (symbol)
      Error Object: #f".
      In the manual, neither one nor the other functionality has an indication of incompatibility with each other. What is the problem? Separately from each other, they do not cause an error.
    • Swathi V. V.
      Hello Can you try a case without shell conduction and see if you are getting the same error?
    • Ant
      You're inattentive. I wrote "Separately from each other, they do not cause an error".
      And you're rude. Where is the shell conduction wall relative to the solid zone? Images may help.
    • Ant
      Ok. There are 3 shell conduction walls. One is between solid and fluid zones, one is between two fluid zones and one is on external boundary of fluid zones. But I tried to deactivate them, leaving only one at a time. Same error. Only if I deactivate all of them there is no error.
      The mesh is 3d and conformal?
      • Ant
        Yes
Viewing 5 reply threads
