loss transfer between Maxwell and mechanical
    • congmin
      hello,
      I have calculated the ohmic loss under two different currents, 200w and 35w, but the loss transmitted to Mechanical is 16W. I have saved the data of MAXWELL and updated the data to Workbench.
      btw, I changed the model size in maxwell. I found that the model size in Maxwell and Mechanical is different. It stands to reason that the model of steady state thermal model should be the same as the model in maxwell
      I want to know what wrong settings and operations caused this situation
Viewing 0 reply threads
