November 1, 2018 at 11:48 pm
bamdadslr
SubscriberHi all,
I want to simulate a current carrying wire from a far point to a simple cylinder, in order to calculate the impedance of the structure in respect to a very far point. To do this accurately, the wire should be loss less and there should be no current leaking from its surface to the surrounding medium (say air or soil for underground cable). Is there any boundary condition in HFSS to simulate the wire with no current leaking through its surface?
- Maxwell, HFSS or Q3D?
- Error
2666
2120
1349
1132
461
