“Low-level communication error -15: Connection was closed” when i run my FSI.
    • fares abbara
      So i have been working for a while on an FSI model for a bifurcating tube with cyclic loading on the outer surface. I have recently managed to get my system going successfully. However, due to high computational time i had to run my model on an HPC service provided by my university. when my model ran i was working on ansys 2023, however the HPC has the 2021 version. To work my way around the issue i redid my model on ansys 19.2 on the university on computers and tried running it on 2021 version on the HPC. Unfortunately the model did not run and i recieved the error message specified in the title of this post. what could the issue possibly be?
      Moreover, i tried running the model again on the 2023 version and i recieved that error as well.
    • Federico Alzamora Previtali
      Hello Fares,
      Are you running intrinsic FSI from Fluent or via Systems Coupling? why is your model not running anymore on 23R1? Can you share more text from the transcript/console to provide more context as to where your simulation fails?
      • fares abbara
        Hello Federico,
        Thank you for your reply.
        I am running my FSI using system coupling. When i reran my model on 23R it was the same error message as 19.2. Here is the text i got after analysis initialization.
        |                           Analysis Initialization                           |
        Traceback (most recent call last):
          File "PyLib/kernel/remote/RemoteObjects.py", line 28, in _nodeCaller
          File "PyLib/physicscoupling/importer/Importer.py", line 36, in setExistingConnection
        RuntimeError: Low-level communication error -15: Connection was closed
        | Low-level communication error -15: Connection was closed                    |
          File "PyLib/main/Controller.py", line 147, in
          File "PyLib/main/Controller.py", line 143, in _run
          File "PyLib/main/Controller.py", line 92, in _executeScript
          File "PyLib/kernel/commands/__init__.py", line 31, in readScriptFile
          File "PyLib/kernel/commands/CommandManager.py", line 169, in readScriptFile
          File "wb2cosim.py", line 4, in
            Solve()
          File "PyLib/kernel/commands/CommandDefinition.py", line 74, in func
          File "PyLib/kernel/commands/__init__.py", line 28, in executeCommand
          File "PyLib/kernel/commands/CommandManager.py", line 122, in executeCommand
          File "PyLib/cosimulation/externalinterface/core/solver.py", line 125, in execute
          File "PyLib/cosimulation/solver/__init__.py", line 123, in solve
          File "PyLib/kernel/util/Memory.py", line 177, in wrapper
          File "PyLib/cosimulation/solver/__init__.py", line 519, in __initializeControlled
          File "PyLib/cosimulation/participantmanager/AnsRpcParticipant.py", line 151, in initializeOutputs
          File "PyLib/physicscoupling/importer/__init__.py", line 93, in setExistingConnection
          File "PyLib/kernel/remote/RemoteObjects.py", line 45, in func
          File "PyLib/ComputeNodeCommand.py", line 94, in newfunc
          File "PyLib/ComputeNodeCommand.py", line 70, in raiseException
        Shutting down System Coupling compute node processes.
