March 7, 2023 at 11:29 am
Mayur Pawar
SubscriberI've been performing magnetostatic analysis on a 4-pole active magnetic bearing of stator made up of iron and copper coil with 250 turns. Excitation is given as Amp*Turns, where the Amp rating is 0.5A. The virtual Force model is solved with parametric analysis of varying currents from 0.2 to 0.5.
The calculated force should come to around 9 Newton but it is on the scale of 0.5-3.5 milliNewton.
March 16, 2023 at 2:19 am
Navya C
Ansys EmployeeHi Mayur,
1) How did you set up your region? Check if all the B field is confined within the simulation domain.
2) Check all the airgaps are maintained as per your calculation
If the problem persists share screenshots of your design, setup and B Field plot on the cross-section of the model
Navya
- Maxwell, HFSS or Q3D?
- Error
3670
2550
1749
1226
582
