LS Dyna
LS Dyna
    • oldbrothermin
      How I use JHC in workbench. n(because the parameter of both JHS-Continuous and JHS-Segmented material card in workbench is different from JHC parameter in LS-Prepost, I used LS-prepost to input JHC material parameter)nMay I know how I select JHC material card in workbench? nThank you n
    • Chris Quan
      For Johnson-Cook material models, you should insert LS-DYNA Keyword Snippet under the selected geometry body to enter the keywords of LS-DYNA JC model. The keyword of the JC model can be created from LS-PrePost. n
    • oldbrothermin
      I never try to use snippetnCould you recommend learning track or other material to study how I use it?n
