September 10, 2022 at 5:20 am
amir.mb1377
SubscriberHello
I installed the latest version of ls dyna. But for mat_197, which was changed in the 2021 update, unfortunately, this update is not included in ls prepost. How long will this update be considered?
September 12, 2022 at 4:23 pm
September 12, 2022 at 8:06 pm
amir.mb1377
SubscriberHi Reno. For the latest version you say. IType=5 in it?
If Itype=5, FYRIM and DFRIM parameters will appear
September 12, 2022 at 8:10 pm
Reno Genest
Ansys EmployeeHello Amir,
ITYPE=5 is still not available in the latest LSPP. Please use a text editor to edit this option for now.
Reno.
September 12, 2022 at 8:16 pm
amir.mb1377
SubscriberHello Reno. How can I send a message to the editor?
September 12, 2022 at 8:18 pm
Reno Genest
Open the model (.k file) with a text editor (Notepad, PSPad, etc.) and modify the *MAT_197 keyword; set ITYPE=5 and add the FYRIM and DFRIM options.
Reno.
September 12, 2022 at 8:22 pm
amir.mb1377
Thank you very much for your guidance. Can you just send an example of editing? Where should I add?
September 12, 2022 at 8:27 pm
Reno Genest
I cannot send files via the forum. Give it a try and let me know how it goes. Please consult the LS-DYNA user manual for the keyword format:
https://www.lstc.com/download/manuals
Reno.
September 12, 2022 at 8:32 pm
amir.mb1377
Ok
thank you very much
September 12, 2022 at 8:34 pm
September 13, 2022 at 5:27 am
amir.mb1377
SubscriberHello Reno. thanks a lot . So I have to add fyrim and dyrim according to the picture. And enter the desired parameters under it?
September 13, 2022 at 4:52 pm
Reno Genest
Ansys EmployeeYes. Also, card 4 will have to be modified according the the manual when ITYPE=5. Please check the manual, because I may have overlooked some details. All you need to know is in the user manual.
September 13, 2022 at 5:10 pm
amir.mb1377
Thank you. You helped me a lot. good luck
September 16, 2022 at 5:17 pm
Reno Genest
ITYPE=5 will be available in the DEV version of LSPP (V4.10) dated after September 16, 2022. Right now it is not available, but it should be in the next few days. Look at the following link:
https://ftp.lstc.com/anonymous/outgoing/lsprepost/dev/
Reno.
September 16, 2022 at 6:08 pm
amir.mb1377
So this week the new version of ls prepost will come
September 16, 2022 at 6:21 pm
amir.mb1377
SubscriberHello Reno. This link you sent me. The last update of ls dyna is 09/14/2022. Isn't Ltype=5 in this?
September 16, 2022 at 10:49 pm
Reno Genest
The Sep16 2022 version is now available. Download it and it should have ITYPE=5 in it. If not, please wait for the next release.
Reno.
September 17, 2022 at 5:54 am
amir.mb1377
SubscriberHelo Reno
Is this version of ls prepost compatible with ls Dyna R13? Can I run in it?
September 19, 2022 at 7:36 pm
Reno Genest
Ansys Employee -
September 21, 2022 at 1:30 pm
amir.mb1377
If I have a solid meshed element, how can I convert it to shell?
September 21, 2022 at 3:31 pm
Reno Genest
Please start a new thread for this question as it is a different topic.
Thank you.
Reno.
September 22, 2022 at 1:09 pm
amir.mb1377
SubscriberHello reno
Ok
Thank you a lot
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2524
2066
1285
1096
459
