Ansys Products
Ansys Products
Ls-dyna automatic surface to surface contact
    • Fady Elshazly
      I have a model solved explicitly with no errors. I tried to solve the model implicitly but it gives the attached error. I beleive it is may be related to an automatic surface to surface contact i have in the model since when i remove the contact, the model solves normally. What would cause this error? and what should i do to solve this?
      Thnaks
    • Andreas Koutras
      Hello, please try with adding the MORTAR option in the contacts. The MORTAR contacts are primarily intended for implicit analysis.
      Here is also a checklist for implicit analysis:
      https://www.dynasupport.com/howtos/implicit/implicit-checklist
      However, this may not help to prevent the error you see.  It seems ls-dyna cannot allocate the required memory.
