LS Dyna
LS Dyna
LS-DYNA Chip Problem
    • javat33489
      Hello dear professionals.
      I have another problem, sorry. I need help.
      I am modeling a test model (downloaded from the forum) before moving on to a complex one. The task of drilling a metal plate. The problem is that I don't have shavings. There are no chips with any material, any fracture model. Most likely the problem is not in the material. Help find her. When drilling, the body behaves like a very elastic one:
      DOWNLOAD ANIMATION
      To explain all the settings is very long, so I attached the K-file DOWNLOAD K-FILE.
      I will be very grateful if you help, I can not find the reason for a very long time.
    • Aniket
      Ansys staff can not download any files on the forum, so if you want to reach a larger audience to get answers from, please insert inline images describing your problem.
      Thanks for your understanding!
      -Aniket
      • javat33489
        OK
    • Andreas Koutras
      Here are some ideas.
      For modeling the drilling process with FEM, you will need to use an ERODING contact, such as *CONTACT_ERODING_SINGLE_SURFACE and also use an appropriate material model (*MAT) that includes failure. For validating your approach, you can start with *MAT_024 in which material failure and subsequent element erosion is controlled by the effective strain at failure FAIL. More complex failure criteria can be also specified with *MAT_ADD_EROSION, *MAT_ADD_DAMAGE DIEM or GISSMO, or *MAT_ADD_GENERALIZED_DAMAGE.  Please look at the corresponding sections in the LS-DYNA manuals.
      I hope this helps.
      • javat33489
        yes, sure! I use both the johnson cook model and the linear polynomial. I have attached pictures of important settings. Please take a look, if you need more pictures, tell me which ones
    • javat33489
      new images
    • javat33489
      I was able to achieve a good result, but no chips
    • javat33489
      Why is the material removed?
Viewing 5 reply threads
